MR84
Sep 13, 2021Aspirant
Upgrade from Nighthawk AC1900 R7000
I have the old Nighthawk C1900 Model R7000 router (purchased in 2015) with Circle 1st Generation installed. Circle stopped tracking history and usage about 3 months ago and I can't resovle the issue...
Sep 13, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Circle product. Most of the people who watch that forum are more likely to have experience with Circle and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
https://www.netgear.com/home/services/smart-parental-controls/
https://community.netgear.com/t5/NETGEAR-Smart-Home-Parental/bd-p/en-home-smart-parental-controls
https://kb.netgear.com/000062109/How-do-I-set-up-and-install-NETGEAR-Smart-Parental-Controls
Good Luck
