Mer1in
Jun 11, 2022Follower
Upgrade from Nighthawk R9000
Dear Netgear Community, I currently have a Nighthawk R9000. I am considering an upgrade. Any suggestions? Thank you in advance. -Merlin
michaelkenward
Jun 12, 2022Guru - Experienced User
Why? What do you want that you can't do now?
Any suggestions?
Not without knowing what you want to do.
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
