_Dolby_'s avatar
_Dolby_
Upgraded cm1000 to cm1200 no internet on R8000p router
I upgraded modem from CM1000 to CM1200. I have a R8000p router that was working fine with cm1000. I get no internet on router when connected to CM1200 modem. I've tried everything and also just factory reset to see if that would fix it. It did not...
What am I missing?
  • SOLVED!  After factory reset I reinstalled Nighthawk app and went through new device setup.  This worked.
1 Reply
