boojiboy71
Sep 08, 2021Aspirant
Upgraded firmware and had a performance degradation.
So I updated to the newest firmware for this model over the weekend and noticed that I lost 50Mbps from my download speed. Since my max for the package that I have is 150Mbps, it was very significant...
michaelkenward
Sep 09, 2021Guru - Experienced User
boojiboy71 wrote:
Did anybody else have that experience? Is it perhaps a sign that my router is going to bite the dust?
Probably not. Equally likely that there is a problem with the firmware you used. It has happened.
Measured how? Not wifi, I hope. That is not reliable and depends on wifi clients.
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
You can reduce the hassle of reconfiguring all those settings by creating a backup of your settings before you reset. Then if something is still broken after the reset, and the new firmware has not fixed it, you can restore the device to its pre-reset state.
You could even try restoring the settings even if the new firmware has fixed the problems, but be prepared for the restore to also bring back your problems.
- boojiboy71Sep 09, 2021AspirantThank you for the response.I did the speed test directly from the router. And I actually spoke too soon about speed levels, when I rolled back the firmware my performance improved, but did not get back to the prior level. Meaning:Prior to firmware update: 148 Mbps downAfter firmware update: 63 Mbps downAfter firmware rollback: 110 Mbps downI was unaware of the factory reset troubleshooting step. I will back up my settings currently, and give that a try later today.Thank you.
- boojiboy71Sep 13, 2021Aspirant
So I have also done the factory reset. But the download times tested at the router still fluctuate a lot. 106 Mbps down to 148 Mbps down.
Are there any more troubleshooting steps? Or is this router starting to go south?
- michaelkenwardSep 13, 2021Guru - Experienced User
Is there any pattern to this? That is a wide variation, but ISPs can have different traffic loads at different times of the day. Likewise the speed test sites.
At least you sometimes get the peak speeds you'd expect.
