PanoWest
Jul 13, 2021Guide
Upgraded firmware and now cannot join EA games
Nighthawk R7000 Firmware update (latest) 1.0.11.123 I had been using update version 1.0.9.88 and everything was fine. Now after the update to 1.0.11.123, I cannot join an EA server to play (Batt...
Jul 14, 2021Guru - Experienced User
what modem/gateway is it connected to?
PanoWest
Jul 14, 2021Guide
Sure,
The modem is a Motorola Surfboard SB6141, the older one not when it was changed to Arris.
Ive unplugged it for 5 minutes and rebooted. No difference. Does it on any browser also.
- plemansJul 14, 2021Guru - Experienced User
Try downgrading all the way to 1.0.9.42
then do a factory reset and a reinstall. don't use a backup configuration
- PanoWestJul 14, 2021Guide
OK, if I understand this correctly, you mean downgrade the nighthawk firmware to 1.0.9.42.
Then do the reset of holding the little button in for 10 seconds again.
Then try the router again.
Not much on the network end of things, hopefully I got it right.
Trying it now.
Ok, didnt work. :smileysad:
