PanoWest
Jul 14, 2021Guide
Upgraded firmware and now cannot join EA games
Nighthawk R7000 Firmware update (latest) 1.0.11.123 I had been using update version 1.0.9.88 and everything was fine. Now after the update to 1.0.11.123, I cannot join an EA server to play (Batt...
Jul 14, 2021Guru - Experienced User
Try downgrading all the way to 1.0.9.42
then do a factory reset and a reinstall. don't use a backup configuration
PanoWest
Jul 14, 2021Guide
OK, if I understand this correctly, you mean downgrade the nighthawk firmware to 1.0.9.42.
Then do the reset of holding the little button in for 10 seconds again.
Then try the router again.
Not much on the network end of things, hopefully I got it right.
Trying it now.
- PanoWestJul 15, 2021Guide
Ok, didnt work. :smileysad:
- plemansJul 15, 2021Guru - Experienced User
And nothing else is having an issue?
not that I can tell. Just this one issue happened right after upgrading the router firmware. I guess I have no alternative but to reinstall Windows? Really hate to do that but I cannot find anything wrong in the PC itself.
