true-local
Aug 22, 2021Follower
Upload speeds dropping to zero
My upload speed is dropping to zero and totally disconnecting my stream and skype. I have a nighthawk xr500 that i am hardwired to and this issue has only come about recently. please help
Aug 22, 2021Guru - Experienced User
What modem/gateway is the xr500 connected to?
how frequently is it happening?
What fixes the issue?
What firmware are you on?
You also might bet better help in the pro-gamer forums that the xr500 specialists are in and not the general nighthawk forum.
