sachb
Jan 24, 2020Tutor
UPNP broken in Netgear R7800 on firmware 1.0.2.68
Hello Netgear community, hope you're all doing well. I'm writing this post just acknowledge that, as per my prior experience with the firmware (V1.0.2.68), the Upnp isn't functioning, and I would...
- Dec 05, 2020
I was mistaken. In firmware V1.0.2.78 UPNP works :-)
fmiranda
Mar 10, 2020Aspirant
You are luck, I'm running firmware V1.0.2.62 and uPNP is not working!!!
I tried V1.0.2.68 and same issue! How can Netgear miss the ball on such a good wifi router?
My uPNP stay always clear, can't connect to games online, can't have my NAS to expose services to outside.
sachb
Jun 03, 2020Tutor
fmiranda wrote:You are luck, I'm running firmware V1.0.2.62 and uPNP is not working!!!
Check whether your upnp service is enabled on the services.msc if you're running windows. I can confirm the upnp is working on 1.0.2.62 but not on the 1.0.2.68
- fmirandaJun 04, 2020AspirantUpnp is working on 1.0.2.62! But not working on 1.0.2.68!
Netgear, get your **bleep** together and release a new firmware update that fixes the upnp and provided the latest security updates.- munkongJun 22, 2020Aspirant
For me, DLNA (uPnP) was working on 1.0.2.68. Then I turned it off, and then turned it back on. From since then, uPnP stopped working - all my videos cannot be streamed. Not only that, SMB access to videos also stopped working for my iPhone and iPad, even though SMB is still working on my macOS. Tried a lot of reboots / configs but can't work. Downgraded to 1.0.2.62 and every video on uPnP and SMB streamed well. Upgraded back to 1.0.2.68 and every video just stopped streaming again. I am now on 1.0.2.62..
