sachb
Jan 24, 2020Tutor
UPNP broken in Netgear R7800 on firmware 1.0.2.68
Hello Netgear community, hope you're all doing well. I'm writing this post just acknowledge that, as per my prior experience with the firmware (V1.0.2.68), the Upnp isn't functioning, and I would...
- Dec 05, 2020
I was mistaken. In firmware V1.0.2.78 UPNP works :-)
sachb
Sep 14, 2020Tutor
They've released a new Firmware 1.0.2.74, will try soon & post back or if someone can try & post the ressults. Hope the upnp is working on the version 1.0.2.74
munkong
Oct 05, 2020Aspirant
Have you tried and saw if upnp is working on version 1.0.2.74?
- Ilias83Oct 11, 2020Guide
No, unfortunately they didn't fix that one.
I upgraded to 1.0.2.74 yesterday and rolled back to 1.0.2.62- fmirandaOct 11, 2020AspirantGuys,
I gave up on Netgear wifi routers. I moved on to Ubiquiti hardware, they have many options and Price ranges. I highly recommend that. - dzesioDec 04, 2020Tutor
firmware V1.0.2.78
UPNP not working
my Synology server does not recognize as UPNP router.
If you have deactivated UPNP for safety reasons, please delete this function.
- dzesioDec 05, 2020Tutor
