sachb
Jan 24, 2020Tutor
UPNP broken in Netgear R7800 on firmware 1.0.2.68
Hello Netgear community, hope you're all doing well. I'm writing this post just acknowledge that, as per my prior experience with the firmware (V1.0.2.68), the Upnp isn't functioning, and I would...
- Dec 05, 2020
I was mistaken. In firmware V1.0.2.78 UPNP works :-)
Ilias83
Oct 11, 2020Guide
No, unfortunately they didn't fix that one.
I upgraded to 1.0.2.74 yesterday and rolled back to 1.0.2.62
dzesio
Dec 04, 2020Tutor
firmware V1.0.2.78
UPNP not working
my Synology server does not recognize as UPNP router.
If you have deactivated UPNP for safety reasons, please delete this function.
- dzesioDec 05, 2020Tutor
- munkongDec 05, 2020Aspirant
munkong wrote:
For me, DLNA (uPnP) was working on 1.0.2.68. Then I turned it off, and then turned it back on. From since then, uPnP stopped working - all my videos cannot be streamed. Not only that, SMB access to videos also stopped working for my iPhone and iPad, even though SMB is still working on my macOS. Tried a lot of reboots / configs but can't work. Downgraded to 1.0.2.62 and every video on uPnP and SMB streamed well. Upgraded back to 1.0.2.68 and every video just stopped streaming again. I am now on 1.0.2.62..
I wonder what settings are different..
- sachbJan 06, 2021Tutor
Oh ya, they did fix the UPNP on version 1.0.2.78, I can confirm it. Bitcomet is green again, I wonder what happened in version .74 & .68?
- munkongJan 06, 2021Aspirant
ok, I will test it by today or tomorrow and give a reply here.
- dzesioAug 17, 2022Tutor
Unfortunately the situation repeats itself in firmware 1.0.2.90
UPNP has stopped working again.
Is there any way to get a port forwarding list in place quickly? I have about 80 items to enter.- FURRYe38Aug 17, 2022Guru - Experienced User
What devices do you have connected?
How is the router configured?
How are you determining that uPnP is failing?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update?
You can try Voxels FW.
