roos5's avatar
roos5
Guide
Jan 05, 2022
Upnp glitched?
Hello,
My Upnp has been acting very weird lately, I've been using my XR1000 with my Xbox Series X for a while with no problem at all. Recently i got my PS5 and while i was using it via Ethernet cable everything was fine with both consoles, as soon as i moved my PS5 to another room and set it up via Wifi i notice that 2 ports (UDP 3074 and 9308) were always being used by the ps5 even if the console was fully turned off, since that i haven't been able to use port 3074 with my Xbox which is my main console for online gaming as of right now,  not even with port forwarding. I really want to fix this since i've been noticing some latency with my xbox, these are the things that i have tried already:
- Restart the router
-Turn off the router
- Unplug the router for 5-8 minutes.
- Fully shutdown the ps5
-Unplug the power cord form the ps5
I'll appriciate your assistance with this.
NOTE: Upnp  Portmap table shows both ports active and still being used by the ps5.
1 Reply
