d0gg
May 13, 2018Apprentice
UPNP no longer works
I just updated to Firmware V1.0.3.16
After the router completed the update, UPNP no longer works.
I have tried rebooting the router several times but the port is not being automatically ...
- May 13, 2018
Thanks for the info! I actually downgraded as well, right after I posted. All is working again!
Is there any place we can submit the bug to Netgear so they can fix it?
Retired_Member
Jun 09, 2018Confirming that on the latest V1.0.0.56, UPNP no longer works. No amount of restart, restore factory settings brings it back.
I_am_TiTaN
Jun 09, 2018Aspirant
Be grateful that it doesn't work as anyone with half an idea would turn it off anyway
