winwellsklo
Feb 02, 2018Aspirant
UPnP not working properly in Firmware V1.0.2.116
I have just updated the firmware to V1.0.2.116 on my R8500 router. Once the update was done, I soon discovered that the UPnP does not function normally: For example, my QNAP NAS cannot detect my ro...
- Feb 20, 2018
Yes, the problem is finally solved by resetting to factory default settings and rebooting for few times.
Thank you.
michaelkenward
Feb 02, 2018Guru - Experienced User
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
