ilovegaming
Nov 22, 2017Aspirant
Upstream and Downstream options not showing in Qos settings
I have a NightHawk AC1900 R700 Firmware Version V1.0.9.12_1.2.23 and I'm trying to enable upstream qos but don't have the option to do so. The Downstream qos option isn't visible either. Are those ...
- Nov 30, 2017Thanks I figured it out once I rolled the firmware back. But thanks for the response and help.
JamesGL
Nov 27, 2017NETGEAR Employee Retired
Hi ilovegaming,
The router uses a new QoS feature. You may refer to the link below.
https://kb.netgear.com/25598/How-do-I-configure-the-Dynamic-QoS-feature-on-my-Nighthawk-router
- JamesGLNov 30, 2017NETGEAR Employee Retired
Hi ilovegaming,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- ilovegamingNov 30, 2017AspirantThanks I figured it out once I rolled the firmware back. But thanks for the response and help.
