dizzydevil
Oct 12, 2015Aspirant
Upstream QOS List Being Reset
Router r7000 Firmware Version V1.0.4.30_1.1.67 Repro steps Go into upstream QOS. Add some (all added via MAC address). Remove some Click apply. Settings seemed to have stuck. ...
- Oct 14, 2015
Can you try the new Beta FW and see if the issue fixed.
JamesGL
Oct 13, 2015NETGEAR Employee Retired
Hi dizzydevil,
Welcome to Community!
I have tried it on my end and I was able to successfully configured the Upstream QoS. Have you tried a different browser or performed a factory reset?
JamesGL
Community Team
- dizzydevilOct 13, 2015Aspirant
I'll reset the device and see if it changes anything. I'm using MS Edge browser but I'm not sure the browser would make a difference since the pages are loading correctly. Is there a known issue with certain browsers? Which were you testing?
- dizzydevilOct 13, 2015AspirantSteps under MS Edge:Chose Revert to factory defaults from under the administration menu. Rebooted or shut off all machines while router was rebooting.Advanced>Setup>QOS>downstream.
-Checked both boxes and hit apply. Router rebooted or 'updating settings'.Advanced>Setup>QOS>upstream
-Checked the box and hit apply. Router rebooted or 'updating settings'Hit upstream Speed test and waited for completion.clicked 'setup QOS rule'
-Deleted warcraft
-deleted everquestClicked add priority rule
-Changed category to MAC address.
-Selected Network Attached Storage Device that had connected already.
-Set priority to low and clicked apply.
-Clicked apply again and verified the settings remained.Clicked Advanced Setup > Wireless Settings
-Turned off 5ghz Radio
-Clicked apply. Router rebooted or 'updating settings'Went back under the Advanced>Setup>QOS>upstream
-All settings had revereted back.Reproduced the configuration steps under IE & Chrome with the same results in that the upstream QOS is reset after enabling / disabling the 5ghz radio and hitting apply. IE actually loaded the welcome / intro page with registration while Edge (the first brower to hit the IP) took me right in like there was no login. Once the intro pages were done, all browsers asked for a login.I also tested it again with all the downstream options turned off and I didn't remove any upstream QOS (just added one via MAC address) and it got cleared when toggling the radio again.- mondenathOct 14, 2015Prodigy
- dizzydevilOct 14, 2015Aspirant
Yes the new firmware and it's QOS interface is keeping the changes now. Thank you.
Do I need to flash back to the offical firmware or will it upgrade automatically when this version or something newer comes out?
