dizzydevil
Oct 12, 2015Aspirant
Upstream QOS List Being Reset
Router r7000 Firmware Version V1.0.4.30_1.1.67 Repro steps Go into upstream QOS. Add some (all added via MAC address). Remove some Click apply. Settings seemed to have stuck. ...
- Oct 14, 2015
Can you try the new Beta FW and see if the issue fixed.
JamesGL
Oct 13, 2015NETGEAR Employee Retired
Hi dizzydevil,
Welcome to Community!
I have tried it on my end and I was able to successfully configured the Upstream QoS. Have you tried a different browser or performed a factory reset?
JamesGL
Community Team
dizzydevil
Oct 13, 2015Aspirant
I'll reset the device and see if it changes anything. I'm using MS Edge browser but I'm not sure the browser would make a difference since the pages are loading correctly. Is there a known issue with certain browsers? Which were you testing?
