saucerman
Jul 21, 2021Aspirant
USB drive does not show up readyshare
I have a seagate 5T ssd that I try to plug into my x6 r8000.....sometimes it is recognized but all of a sudden the connect fails and then it will not connect at all runnubng firmware V1.0.3.48_1.1.3...
michaelkenward
Jul 22, 2021Guru - Experienced User
You have an SSD in a USB enclosure?
ReadySHARE is picky about the USB devices it accepts.
This list will give you some clues, although it is far from comprehensive:
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
Not sure that any SSD works. How is yours formatted? Any partitions?
saucerman
Jul 22, 2021Aspirant
it's an extenal 5 tb ssd drive that is connected via usb to the router. The partition is ntfs. It worked fine for a while then all of a sudden I have trouble seeing it. Works perfect if I connect it to any pc...
- michaelkenwardJul 23, 2021Guru - Experienced User
What have you changed in the meantime?
saucerman wrote:
iWorks perfect if I connect it to any pc...
Unfortately, that guarantees nothing. PCs can use drivers that accommodate devices that will not work in a router.
- saucermanJul 29, 2021Aspirant
the only thing that changed was the firmware of the router...I tried to revert back to the original one and that' didn't work either...
I was running KODI on the harddrive for over a year...the only thing I added to the harddrive were movies or TV shows. That version of KODI or unix hasn't changed.
