CravingphoeniX
Aug 25, 2021Follower
usb printer setup without readyshare.
Okay So my parents' router was recently fried in a bout of terrible storms. I used to swear by netgear, and nighthawks, so because Asus' customer service was really (word that rhymes with kitty but s...
michaelkenward
Aug 26, 2021Guru - Experienced User
CravingphoeniX wrote:
Is there any way to install a usb printer without the stupid usb shareware
Forgive me if I have missed something important in the rest of your message, which doesn't seem to be about getting your printer to work, but can you explain what you mean by "stupid usb shareware"?
Shareware?
Getting a USB printer to work is a one-off process that inevitable requires installing drivers for the printer on every PC that plans to use that printer.
It is the nature of the beast. No drivers=no work.
At least, that's with the printers I have used. Maybe your unnamed printer uses some other magic process to work.
Of course, we don't know how you expect to talk to this printer, so this is all guesswork. I assume that the printer is plugged into the R7000. But then there is the "wifi versus network" question. Both are possible.
If you mean the "NETGEAR USB Control Center utility", it is mostly there to manage other features like shared USB storage, but if you do need it for your printer, a PC that can't handle a 4 MB program may have a hard time doing anything.
Portwey84
Aug 26, 2021Virtuoso
CravingphoeniX I don't have Netgear's USB Readyshare utility downloaded and I have my HP printer connected via bluetooth to all of my computers (all four of them) plus two iphones and a Nokia. My HP drivers are installed on my desktop/laptops and the HP app on my phones.
- michaelkenwardAug 26, 2021Guru - Experienced User
Thanks for that. Very helpful.
Is the HP plugged into the router? Just wanted to confirm this to get a complete picture.
- Portwey84Aug 26, 2021Virtuoso
michaelkenward Printer is connected via WiFi over 2.4ghz, sits about 15 feet away from the router. If I need to print something, I just do it via the official Hp app, either on my phones or via the Microsoft App store Hp app. I think the official Hp App downloads the necessary driver files anyway in order to allow printing.
