Wolfgang_'s avatar
Jul 27, 2015
USB Storage share names changes all the time
Hi,
I have a 4TB disk with three partitions attached to my R7000 (latest firmware V1.0.4.30_1.1.67). Very often the share names get mixed up, sometimes two partitons have the same share name. I have not figured out what the exact pattern of this behaviour is. Rebooting did not help. This is very annoying and I can't get OSX Time Machine to reliably use always the correct partition. Any ideas?
  • JamesGL's avatar
    JamesGL
    Aug 05, 2015
    Wolfgang_,
    Please do a factory reset on the router. Since you have loaded a new firmware it is advisable to do a factory reset and reconfigure it.
    JamesGL
    Community Team
  • Anybody else noticed that or am I the only one ? Is this maybe a known issue ?
    • JamesGL's avatar
      JamesGL
      Master
      Hi Wolfgang_
      I would like to ask if it has the same issue on the previous firmware prior to updating it to the latest one?
      JamesGL
      Community Team
      • Wolfgang_'s avatar
        Wolfgang_
        Tutor
        Hi JamesGL,
        I do not think that was an issue in the previous firmware version. I was hoping I can avoid switching back to the previous version.
        Wolfgang
