TontMorton
Dec 20, 2020Follower
Use Netgear Router with T-Mobile Home Internet
I have recently replaced Spectrum with T-Mobile Home internet and need to know how to use my router with the T-Mobile interface
bjkaufman
Aug 07, 2021Aspirant
Will the Netgear EX6400 work with the T-mobile NOK 5G21 Gateway Internet device. If so, how would I hook it up? Does it have to go through a router? I do have a Linksys EA6350 router.
- michaelkenwardAug 08, 2021Guru - Experienced User
That is probably an unanswerable question without a lot more information.
First you need to work out what this "T-mobile NOK 5G21 Gateway Internet device" can do. We can't do the research for you. Ask the people who made it how you can connect it to a router or extender.
Then you need to decide what you are doing with this Linksys EA6350 router.
The you could look at what the EX6400 is intended for. It is a wifi extender. That means it works with your existing wifi and router and spreads it out into a wider area. How you do that – as a wifi repeater or a wireless access point – is up to you.
None of your questions has anything to do with the Nighthawk WiFi Routers covered in this bit of the Netgear community.
Finally, please do not hijack a discussion that someone else has started on a completely different subject. If you do want help, try starting your own discussion and pick a section that has something to do with what you want to ask about. This might be one place:
