myusrn
Feb 02, 2021Aspirant
use of all ethernet ports and access to admin page after changing to bridge mode
I have a nighthawk c6300 modem+router+wifi device. My isp, spectrum, has not bumped the firmware revision up from the V2.01.26 release which makes the web admin UI only accessible from an old intern...
- Feb 04, 2021
> Model: C6300|AC1750 Cable Modem Router Docsis 3.0
C6300[v1] or C6300v2? Look for "Model" on the product label.
> wrt q3 with the c6300 configured with Router = Yes -> No = modem/bridge
> only setting i could not access a c6300 web admin UI at 192.168.0.1 or
> 192.168.100.1 or routerlogin.com from my laptop plugged directly into a
> c6300 ethernet port or connected to a dhcp+router+wifi access point
> device connected to c6300 when in modem/bridge mode."could not" is not a useful problem description. It does not say
what you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
If you try that, then I'd expect you to need to configure the
computer manually with an IP address (static) on the same subnet as the
router. In modem-only mode, the C6300 won't provide a DHCP server, so
the computer might self-configure inappropriately. It might be
educational to fetch a User Manual for a plain cable modem (like, say, a
CM500), and look at its "Troubleshooting" section.> [...] Is there a factory reset pin hole located on back or ??? and
> does pressing it flip device back into Router = Yes setting [...]Yes. Visit http://netgear.com/support , put in your (actual) model
number, and look for Documentation. Get the User Manual (at least).
Read. Look for "Factory Default Settings" and/or "Reset button". Also
interesting: "Manage the Modem Router Configuration File".
antinode
Feb 03, 2021Guru
> [...] will this break ability to use the ethernet ports on my c6300?
Yes. (Except for the one which connects to the WAN/Internet port on
the new router.)
> q2. Would devices connected to those ethernet ports now end up pulling
> dhcp addresses from the modern router+wifi+wifi mesh device i have
> plugged into one of those ethernet ports?
Huh? All your client devices would need to be connected to the new
router, which would also act as your DHCP server. The C6300 would be a
modem only.
> q3. Once configured to be in bridge mode would i be able to access the
> c6300 web admin UI from a device wifi connected to my modern
> router+wifi+wifi mesh device [...]
The C6300-as-modem should be accessible at "192.168.100.1".
- myusrnFeb 03, 2021Aspirant
Thanks for the responses that helps.
Wrt q3 response would the c6300-as-modem only device web admin UI at 192.168.100.1, vs 192.168.0.1 its currently accessible at, be reachable from a device connected to my new dhcp+router+wifi access point device that is plugged into c6300 ethernet port 1? In other words would i have to plug something directly into c6300 ethernet port 1 to access that web admin UI or should it be accessible by device plugged into new router+wifi access point device?
Wrt q2. response thanks for clarification didn't know whether c6300 in router = No / as a modem only device would enable ethernet ports 2, 3 and 4 to operate like switch ports leveraging whatever was plugged into ethernet port 1 as upstream feed.
Wrt q1 response just to confirm does new dhcp+router+wifi access point have to be plugged into the c6300-as-modem ethernet port 1 or will it work using any of the other ethernet ports also? I ask because my c6300 is currently located in attic where my house cableop coax house terminates and i have cat6 ethernet runs orginating from there to other parts of house. So i'm not sure exactly which c6300 ethernet port the run currently feeding new dhcp+router+wifi access point device is connected to.
- antinodeFeb 03, 2021Guru
> that is plugged into c6300 ethernet port 1? [...]I believe so. Have you tried "192.168.100.1" when it's in
modem+router mode? "192.168.100.1" is a special DOCSIS address. I'd
expect it to work in either mode.> Wrt q2. response thanks for clarification didn't know whether c6300 in
> ethernet port 1 as upstream feed.In modem-only mode, you can use only one of the LAN Ethernet ports.
The remaining LAN ports on the C6300-as-modem are not connected to the
LAN ports on the new router.> q4. Does new dhcp+router+wifi access point have to be plugged into
> ports also?I don't know. I'd guess that you could use any one of them, but I'd
use 1. It should be easy to run the experiment. No matter which one
you use, you can use only one of them.- myusrnFeb 04, 2021Aspirant
wrt q1/q4 my new dhcp+router+wifi access point successfully made use of the c6300's Router = Yes -> No = modem/bridge only configuration uplink using whatever one of the ethernet ports on back of c6300 it was plugged into previously. I can't tell which because i have c6300 stuck in attic and don't want to have to go up there if i can avoid it ;)
wrt q2 it would seem any one of the c6300 ethernet ports, but at most only one, can host the downstream dhcp+router+wifi access point device ethernet connection when c6300 is configured with Router = Yes -> No = modem/bridge only setting.
wrt q3 with the c6300 configured with Router = Yes -> No = modem/bridge only setting i could not access a c6300 web admin UI at 192.168.0.1 or 192.168.100.1 or routerlogin.com from my laptop plugged directly into a c6300 ethernet port or connected to a dhcp+router+wifi access point device connected to c6300 when in modem/bridge mode.
q5 when c6300 is configured with Router = No = modem/bridge only setting how do you restore Router = Yes setting given what appears to be an absence of any web admin UI? Is there a factory reset pin hole located on back or ??? and does pressing it flip device back into Router = Yes setting where a web admin UI is accessible at 192.168.0.1 or routerlogon.com so one can reconfigure all their prior settings if they want to go back to them?
