myusrn's avatar
myusrn
use of all ethernet ports and access to admin page after changing to bridge mode
I have a nighthawk c6300 modem+router+wifi device.  My isp, spectrum, has not bumped the firmware revision up from the V2.01.26 release which makes the web admin UI only accessible from an old intern...
  • antinode's avatar
    antinode
    Feb 04, 2021
    > Model: C6300|AC1750 Cable Modem Router Docsis 3.0
       C6300[v1] or C6300v2?  Look for "Model" on the product label.
    > wrt q3 with the c6300 configured with Router = Yes -> No = modem/bridge
    > only setting i could not access a c6300 web admin UI at 192.168.0.1 or
    > 192.168.100.1 or routerlogin.com from my laptop plugged directly into a
    > c6300 ethernet port or connected to a dhcp+router+wifi access point
    > device connected to c6300 when in modem/bridge mode.
       "could not" is not a useful problem description.  It does not say
    what you did.  It does not say what happened when you did it.  As usual,
    showing actual actions (commands) with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
       If you try that, then I'd expect you to need to configure the
    computer manually with an IP address (static) on the same subnet as the
    router.  In modem-only mode, the C6300 won't provide a DHCP server, so
    the computer might self-configure inappropriately.  It might be
    educational to fetch a User Manual for a plain cable modem (like, say, a
    CM500), and look at its "Troubleshooting" section.
    > [...] Is there a factory reset pin hole located on back or ??? and
    > does pressing it flip device back into Router = Yes setting [...]
       Yes.  Visit http://netgear.com/support , put in your (actual) model
    number, and look for Documentation.  Get the User Manual (at least).
    Read.  Look for "Factory Default Settings" and/or "Reset button".  Also
    interesting: "Manage the Modem Router Configuration File".
