chiengweesiong
Oct 29, 2018Aspirant
Use of Nighthawk with Arlo Pro 2 in China
Hi, I have been using my Arlo Pro 2 with Nighthawk R8500 since last week in China. It worked well until three days ago, with error message saying the base is offline. I tried all troubleshootings inc...
- Oct 29, 2018
There are no port forwarding required for operating an Arlo Base (or the base-less Arlo camera models). Port 443/TCP and 80/TCP must be open for outgoing connections.
Any indications of malfunction on the Arlo Base -> My Arlo base station is offline; how can I troubleshoot it? ?
I suggest to file a similar post on https://community.arlo.com/ as Arlo is an independent organisation now.
Because of the "great wall", things might work different in mainland China. No idea or insight how Arlo has set-up their infrastructure, DNS names, and so on for China.
schumaku
Oct 29, 2018Guru - Experienced User
chiengweesiong
I guess you are right as the opened ports do not change anything. I shall file in arlo community as suggested. I believe the great wall plays a part in this. Thanks.
