VJLoes2513
Dec 07, 2020Follower
Use with Metronet
Does anyone know if this router works well with Metronet service? We have it and used it with Mediacom and hope to use it with our new service.
Dec 08, 2020Guru - Experienced User
Its just a router. Depending on what metronet uses for gateways, you should be able to get it working. You might have a double nat situation (that can be fixed) but we won't know until you get your gateway device.
