K8ohlric
Jun 17, 2021Follower
Used Nighthawk X6S serial number already registered
I bought a used nighthawk X6S from a friend. I did a factory reset and was able to connect to the WiFi with the given credentials. But when I try to get into my account and change the network name or password, it tells me the serial is already registered in the database. How can I clear it from the database?
1 Reply
K8ohlric wrote:
But when I try to get into my account and change the network name or password, it tells me the serial is already registered in the database.What account is this? What database? Most settings do not need you to register anywhere.
NETGEAR Product Registration FAQ | Answer | NETGEAR Support
