fixingstill
Oct 25, 2022Guide
Using 5GHz for client bridge then the 2.4Ghz cannot be used?
Using 5GHz for client bridge then the 2.4Ghz cannot be used? Say I have a room I can't run ethernet cable to. I set up a R7000 as client bridge and connect to the main router via the 5Ghz. Then, I c...
- Oct 30, 2022
This is why I use DD-WRT.
Oct 25, 2022Guru - Experienced User
In bridge mode, the wireless is just used for the router===router communication. Only the ethernet ports are usable for other devices.
You're looking for a repeater/extender mode. Which some devices do have (not all) but without a model, its tough to know if you have that option.
- fixingstillOct 30, 2022Guide
