TerryJColes
Jun 29, 2020Luminary
Using a Static IP Address on a Raspberry Pi Connected to my Nighthawk Router
Hi, I have a couple of Raspberry Pis connected to my Home Network which is provided by my Netgear Router. Ideally I want to set up a static IP Address for each of these Pis, but I cannot make th...
- Jun 30, 2020
schumaku wrote:So t the end of the day, what went wrong and broke the Pi <-> D7800 connection and the Internet connection finally?
The router was unaware of the presence of the Webserver, so didn't route Google traffic when I was trying to use the Static IP.
labatt
Jun 29, 2020Mentor
TerryJColes wrote:'Configure the Raspberry Pi staticly. That means going into the Pi and assigning an IP address, mask and gateway. '
I have been configuring the IP address statically, eg:
# Static IP configuration: interface eth1 static ip_address=192.168.1.98/24 static routers=192.168.1.1 static domain_name_servers=8.8.8.8 metric 200What do you mean by 'mask and gateway' in this context?
I suspect when you did the actual configuration on the Pi you were asked mask. That does not show when doing the command you gave.
Normally when doing the actual assignment there is a mask question. Is the .98 address within your DHCP scope? If so that can cause issues.
Can you ping the Pi? If not then that would be where to start assuming the .98 is outside of the DHCP scope.
If you do a ifconfig eth1 you should see the mask. Here is output on my Pi.
ifconfig eth0
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.220 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::1683:1051:7637:eeeb prefixlen 64 scopeid 0x20<link>
ether b8:27:eb:57:7d:03 txqueuelen 1000 (Ethernet)
RX packets 1561476 bytes 193229943 (184.2 MiB)
RX errors 0 dropped 1 overruns 0 frame 0
TX packets 961779 bytes 114655160 (109.3 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
TerryJColes
Jun 30, 2020Luminary
labatt wrote:> I suspect when you did the actual configuration on the Pi you were asked mask. That does not show when doing the command you gave.
I don't understand what you mean by 'asked mask'? This is not done by some kind of wizard. It is done by editing the file dhcpcd.conf. AFAIK the subnet mask is defined by the /24 in the declaration.
