bluepuz
Jan 30, 2021Follower
using an old cable modem router as wifi router only
HI everyone...
Just curious
I just upgraded fro a 500mbps internet to a 1GBps.
I have an old netgear c7000v2 cable modem router (docsis 3.0) that i am not using
and i just bought a netgear cm1100 docsis 3.1 modem only...
any way that i can use my old netgear to use as a wifi router only... while i save up to buy a netgear wifi 6 mesh system?
a step-by-step procedure would be nice as i am not very technically knowledgable when it comes to networking.
any help i would gladly appreciate.
THanks in advance!
1 Reply
> [...]I know of none, unless you can find a way to create an Ethernet
WAN/Internet port on the C7000v2.It should be possible to configure a C7000v2 (or any other Cxxxx
model) as a wireless access point, but that's not a router. For
useless-to-you details, see, for example:https://community.netgear.com/t5/x/x/m-p/1463500
That's written for a Netgear C6300-as-WAP, but the steps are about the
same for any other router (any make/model) which lacks a one-step WAP
option. But that's not much use without a router.
