billmessmer's avatar
billmessmer
Follower
Nov 11, 2022
Using an old Netgear 91 router to broadcast WiFi in my barn
I have a used Netgear 91 Router. I ran 200FT of Shielded Cat 7 wire in a conduit to my barn.  The router has power. LAN 1,2,3,4, and Internet WAN? port a reset, USB port and a power button.  I was told by someone at Nighthawk that I leave my Home Nighthawk 7000v Router modem from LAN port one, Travel the cat 7 wire to the Netgear 91 router and connect it to the yellow internet port WAN?  when it powers up, I see the power light, 2.5 and 5G lights light also the internet light and the Wi-Fi lights. But I am not receiving Internet on a Laptop in the barn that only receives internet thru Wi-Fi.
If I take the CAT 7 wire and hook it into the Lan network port on a different laptop, I can receive internet. So, the CAT 7 wire is a good connection to the Nighthawk 7000v House Router/Motem.. What do I have to do to the Netgear 91 router to use it to project the internet in the barn by Wi-Fi? when it is hard wired?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    billmessmer wrote:
    I have a used Netgear 91 Router SR#
    That is not a Netgear model number. It is more likely to be the default SSID for the wifi on it.
    Look at the label on the thing for the model number.
    If you are saying that this unknown barn router is wired to a second router somewhere else, then the barn router should be set up in wireless access point (AP) mode.
    How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
    Or visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Look for the model number on the label on the device.
    Check the manual for instructions on how to put it into AP mode.
