jjkatz's avatar
jjkatz
Follower
Jul 13, 2020
Using Both Wired and Wireless with Access Point Setup
Considering this router to use as an access point on my existing home network (AT&T U-Verse), and I have a quick question. If I set it up as an access point, are the Ethernet ports still available or...
  • antinode's avatar
    Jul 13, 2020
    > [...] If I set it up as an access point, are the Ethernet ports still
    > available or is it wireless-only in that mode?
       The LAN Ethernet ports should work, too.  That'd be true for
    practically any router when configured/used as a wireless access point.
