accuangelist
Jan 04, 2022Follower
Using C7000 v2 and Netgear app but seeing no armor security button
I have uninstalled and reinstalled the app, rebooted the router numerous times, but I still don't have the "Security" button. The only buttons I do see are: Device Manager Wifi Settings Guest ...
Jan 04, 2022Guru - Experienced User
I would check with Armor to see if the C series modems are supporting Armor.
Netgear has set up a community forum specifically for the Armor product. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://www.netgear.com/landings/armor
Something to contact NG support about.
https://my.netgear.com/support/contact.aspx
Thank you.
