GirffyB
Feb 11, 2022Aspirant
Using cable modem/router combo only as modem
 I'd like to know how to run my existing modem/router (C6250|AC1600) only as a modem and use a separate router (Nighthawk AX6 AX4300 RAX45). Is there a way to do this?
- Feb 11, 2022Yes, you should be able to find a router mode option on the modems web page, should be under Advanced Tab/Adanced Settings Router mode may say Yes and No. Select No. May find a Bridge mode option here as well.
 Reivew the online user manual for this model modem for this information if you can find it.
Feb 11, 2022Guru - Experienced User
GirffyB
Ok, I saw that page when I was looking, but didn't think it could be that simple. Go figure. Thanks for the help.
