DrBlingDaddy
Mar 03, 2020Aspirant
Using CM1150V with RAX120. Is port aggregation possible?
For normal operation of the two devices for internet it looks as if the WAN port on the RAX needs to be connected to port one on the 1150. But in order to use port aggregation the RAX, ports 1 and 2 ...
- Mar 03, 2020
Okay, so I figured it out. I needed to enable WAN aggregation on the RAX under "Setup", "Internet Setup", and "Ethernet Port Aggregation" under "Advance" on the 1150.
DrBlingDaddy
