GnD62798's avatar
GnD62798
Using Netgear R8500 Router
Have Cox cable internet speed Ultimate 500.  Can only get router download speeds at 200mb or so.   Any idea on what might be going on with router settings so that I can increase the download speed from ISP?   Thanks!
  • plemans's avatar
    What modem do you have?
    What speeds do you get directly off the modem?
    What firmware is on the router?
    Make sure qos, access control, traffic monitoring, and parental controls are all disabled and then reboot the router.
    • GnD62798's avatar
      GnD62798
      What modem do you have?    Netgear CM1000
      What speeds do you get directly off the modem?   Cox tech just left and using his meter shows about 600mb
      What firmware is on the router?   Just upgraded router firmware to V1.0.2.144
      Make sure qos, access control, traffic monitoring, and parental controls are all disabled and then reboot the router. These are all off and have rebooted router with similar download speeds.
      Thanks
      • plemans's avatar
        Not the cox tech, but you.
        directly connect a pc/laptop to the modem and see what you get.
        the 200mbps that you're getting, is that wired or wireless?
        What wired speeds do you get?
