GnD62798
Feb 08, 2021Aspirant
Using Netgear R8500 Router
Have Cox cable internet speed Ultimate 500. Can only get router download speeds at 200mb or so. Any idea on what might be going on with router settings so that I can increase the download speed fr...
Feb 08, 2021Guru - Experienced User
Not the cox tech, but you.
directly connect a pc/laptop to the modem and see what you get.
the 200mbps that you're getting, is that wired or wireless?
What wired speeds do you get?
GnD62798
Not the cox tech, but you. Directly connect a pc/laptop to the modem and see what you get.
---->When he left, i brought my laptop up and connected directly (wired) to the back of the modem and rec'd about 350 or so
the 200mbps that you're getting, is that wired or wireless? --->It is wireless, using iPhone. These are the same speeds i saw when the ISP was at Ultimate 300 speed
What wired speeds do you get? Wired thru a switch is at 330-350 via a Firestick device
- plemansFeb 08, 2021Guru - Experienced User
GnD62798 wrote:Not the cox tech, but you. Directly connect a pc/laptop to the modem and see what you get.
---->When he left, i brought my laptop up and connected directly (wired) to the back of the modem and rec'd about 350 or so----You're paying for 500? you should get at least that hardwired in.
the 200mbps that you're getting, is that wired or wireless? --->It is wireless, using iPhone. These are the same speeds i saw when the ISP was at Ultimate 300 speed----It might be a device limitation and not a router limitation. If you already weren't able to max out a 300mbps connection, then the bottle neck wasn't the ISP speeds.
What wired speeds do you get? Wired thru a switch is at 330-350 via a Firestick device---wireless won't be as fast as wired. But again, if you're paying for 500, you should be able to get that wired. Maybe not on a firestick because I'm not sure how reliable the firestick is at speedtesting .
- GnD62798Feb 08, 2021Aspirant
Thanks for your feedback.
