Flo_Paris
Dec 10, 2020Tutor
Using Nighthawk as an access point
Dear Community, I have internet via Cable. My router is in the basement of my home - and the wifi signal pretty bad on the first floor. I bought a Nighthawk D7000v2 and wants to use it as an Acces...
feobrien
Dec 10, 2020Tutor
I just had one more thought. When you set up the router as an "access point" did you change the Wi-Fi SSID to something different than the one downstairs? I'm wondering if your devices are still trying to connect to the one downstairs and given the weak signal that's why they keep dropping. You might want to give the "access point" SSID a different name and snure you are connecting to that one.
- Flo_ParisDec 10, 2020Tutor
Thank you so much Feobrien !
I did connect the "yellow" port to my router - and use the other as a pure LAN for my laptop. This connection works ok, but get disconnected from time to time.
I´ll try this weekend your SSID hint.
Again, a huge thanks !
- Flo_ParisDec 12, 2020Tutor
Hi Feobrien,
just a short heads-up : I´ve reset my hw and just tick in the box Access Point in the router portal. Seems to work properly now.
I´ve also change my ethernet cable - and the internet light is now white, ie. better signal.
A huge thanksk for your support - it was super helpful.
Flo
- feobrienDec 12, 2020Tutor
Glad you got your problem resolved.
