Jrut007
Jun 14, 2021Follower
Using R7000 with C7000
So I'm looking to do software updates and use the nighthawk app, but everytime I use the app I get an error saying can not find router even though I am connection to the router in my home with the C70...
antinode
Jun 14, 2021Guru
C7000[v1] or C7000v2? Look for "Model" on the product label.
> Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0 [...]
Nothing to do with anything?
> [...] I'm looking to do software updates [...]
Of what? You can't change the C7000[vX] firmware.
https://kb.netgear.com/000036375
> [...] everytime I use the app I get an error [...]
Forget the app, and use a web browser?
> [...] I am connection to the router in my home with the C7000 internet
> turn off because I just use it as a modem [...]
What, exactly, did you do to the C7000? Disable its router, or
disable its radios, or what?
Visit http://netgear.com/support , put in your cable modem+router
model number, and look for Documentation. Get the User Manual (at
least). Read. Look for "Cable Your Modem Router to a Router and Use
Bridge Mode" and "Control the Wireless Radios". Which did you do?
Further reading might not hurt, either.
> [...] How do I fix this
I'm not yet sure what "this" is.
