Skykid
Feb 05, 2021Aspirant
Using R7000 with mobile hotspot for internet
Hello, I have 2 Netgear R7000 wireless routers. My only source of internet is mobile hotspot data. I want to make a network and feed it internet from the 4G mobile phone hotspot. Various computers...
Feb 05, 2021Guru - Experienced User
what actual hotspot do you have?
Skykid
Hi, thanks for the reply, using a Note9 phone.
- SkykidFeb 05, 2021AspirantOh, how painful, just got off the phone with netgear technical support. They said I need a modem. Why cannot the R7000 be configured to accept internet from a mobile hotspot from my Note 9 phone?
It sounded like there were other people doing this or something similar from these forums.
This video shows a person doing it with a TP Link router...is that somehow different or superior to the netgear R7000? Watch "How to Share & Connect 3G / 4G Mobile Hotspot To WiFi Router Tutorial" on YouTube
https://youtu.be/4ykqFgJi-ZE
I have two of the R7000 routers, so can one of them tie into the mobile hot spot on the note 9 phone and the other router be the network router to connect other computers, printers, etc?
Thanks!
Skykid - plemansFeb 05, 2021Guru - Experienced User
so you're using a phone as a hotspot.
You could try setting up the R7000 as a wireless extender as it has that mode.
How do I enable the extender mode feature on my Nighthawk router? | Answer | NETGEAR Support
- SkykidFeb 05, 2021AspirantThanks, this sounds like it may be what the person did in that video link I sent. I'll give it a try and keep you posted about the outcome.
Thanks much!
Skykid- antinodeFeb 05, 2021Guru
> I have 2 Netgear R7000 wireless routers. [...]
Firmware version?
> hotspot. Various computers and printers will be on the network.That's a little vague. Presumably, your wireless devices could
connect directly to the hotspot, and a wireless bridge could let you
connect otherwise-wired-only devices to the hotspot. I see no real
need to "make a network" using another router. But I'm always open to a
good counter-argument.Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Set Up the
Router in Bridge Mode".> Can it be done with 2 of the R7000 routers? I read about repeaters and
> bridge mode...but am lost on what way to go.
What did you read where?
The repeater mode on these routers is approximately useless. Look
for "Set Up the Router as a WiFi Repeater" in the User Manual, and read
the restrictions.I haven't tried it, so I know nothing, and I'm not convinced of the
wisdom of using a router to "make a network" and hiding it behind
another router (the hotspot), but you could try configuring one R7000 as
a wireless bridge (to connect wirelessly to the hotspot), and one as a
router for your new "a network" (with its WAN/Internet port connected to
a LAN port on the R7000-as-bridge).> Watch "How to [...]
Only if I run out of sand to rub into my eyes.
