witaker
Jun 29, 2019Aspirant
Using R7800 bridge mode (ping general failure)
Hi. Recently, I bought and use R7800 due to a device failure. I have error after changing the switch Symptoms experience internet loss non-periodicly every 1 to 2 hours. As a result of continuing ...
- Jul 04, 2019
Hi.
I decided not to use bridge mode, but to take two IP Subnet bands. (I changed it to Router mode.)
In bridge mode, intermittent break still occurs, but the problem does not occur after changing to Router mode. Perhaps there is a problem with the bridge mode operating on the R7800.
Anyway, I avoided that problem, and after changing to Router mode, I need to set up NAT in a small way, but I'm satisfied.
witaker
Jun 30, 2019Aspirant
Hi, thank you for your reply.
I'm not using wireless AP, I'm only using wired.
The firmware is V 1.0.2.62, but I know it's up to date.
michaelkenward
Jun 30, 2019Guru - Experienced User
So what do you mean by bridge mode?
That usually means that you have a router to router link running over wifi.
What is this "Gateway"?
It might also help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
Is that the gateway?
