airwolf28's avatar
airwolf28
Follower
Dec 29, 2020
Using the ExpressVPN on a R6400v2 Router
I just purchase the ExpressVPN for myself and I am loving the privacy that they are giving. When I was in the company's website, they states that I can put in the ExpressVPN on my router. I tried to find my router but it's not listed. I went into my router settings and saw the VPN option but it was the different type of VPN that I don't want to use. Is there a way for me to use the ExpressVPN on that router or can I change the option from the VPN that is installed (Open VPN) to the VPN of my choosing (ExpressVPN)?
1 Reply
  • plemans's avatar
    No, there's not.
    You do have options but its all 3rd party.
    If you have R6400v1, you can put ddwrt on it and that's supported through expressvpn.
    You won't find help on the official forums for something like that.
