Baneling's avatar
Baneling
using the R7200 as an Access Point
Hi all, I replaced my R7200 with an R300.  Now I want to use the R7200 on another floor as an access point.  I reset to router to factory defaults, plugged the network port into one of the lan ports on the router.  the router has an ip address of 192.168.1.1.  When I try to access that on a browser to get into the config page, it doesn't work.  the site doesn't work.  I also tried with the network cable plugged into the WAN port. how do I connect to the router?
