anirguha
Jan 30, 2022Aspirant
Using WPA3 on Nighthawk R7000 Router
I am using a Netgear Nighthawk R7000 Router for several years now. Does this router support the WPA3 security option for WiFi connection? I am using the latest firmware available on the router. J...
- Jan 30, 2022
No it doesn't.
You'd have to upgrade to a newer hardware that supports wpa3 if that's what you're wanting.
Keep in mind, some older devices struggle with wpa3.
Jan 30, 2022Guru - Experienced User
No it doesn't.
