anirguha
Jan 30, 2022Aspirant
Using WPA3 on Nighthawk R7000 Router
I am using a Netgear Nighthawk R7000 Router for several years now. Does this router support the WPA3 security option for WiFi connection? I am using the latest firmware available on the router. J...
- Jan 30, 2022
No it doesn't.
You'd have to upgrade to a newer hardware that supports wpa3 if that's what you're wanting.
Keep in mind, some older devices struggle with wpa3.
Portwey84
Jan 30, 2022Virtuoso
anirguha So you have the answer you sought, but here's a thread from a couple of years back:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-AC1900-has-MFP/td-p/1773101
Always worth using the search function, especially when asking about the R7000 AC1900, which contains enough threads and repeated questions about the same things. That's not me being in anyway sarcastic, it's just being helpful, that's what the search function is for.
I've just consigned my R7000 AC1900 to the darkest recess of my attic where it belongs. Replaced it with a TP-Link AX6600 GX90 which does have WPA3.
anirguha
Portwey84 thanks for your response and the link. I have gone through this before and searched at length for WPA3 before posting my question. No where the answer is conclusive (prior to this). In fact while performing a Google search on WPA3 on Nighthawk R7000 I found an article on Netgear site that says just the opposite. https://kb.netgear.com/000060425/How-do-I-enable-WPA3-security-on-my-NETGEAR-router
But I was almost convinced of the answer myself before even I posted my thread. The response only confirmed it.
BTW, now I am curious to know if there is any Netgear router at all that supports WPA3.
