anirguha
Jan 30, 2022Aspirant
Using WPA3 on Nighthawk R7000 Router
I am using a Netgear Nighthawk R7000 Router for several years now. Does this router support the WPA3 security option for WiFi connection? I am using the latest firmware available on the router. J...
- Jan 30, 2022
No it doesn't.
You'd have to upgrade to a newer hardware that supports wpa3 if that's what you're wanting.
Keep in mind, some older devices struggle with wpa3.
anirguha
Portwey84 thanks for your response and the link. I have gone through this before and searched at length for WPA3 before posting my question. No where the answer is conclusive (prior to this). In fact while performing a Google search on WPA3 on Nighthawk R7000 I found an article on Netgear site that says just the opposite. https://kb.netgear.com/000060425/How-do-I-enable-WPA3-security-on-my-NETGEAR-router
But I was almost convinced of the answer myself before even I posted my thread. The response only confirmed it.
BTW, now I am curious to know if there is any Netgear router at all that supports WPA3.
Jan 30, 2022Guru - Experienced User
For that link, please review the following on that page:
This article applies to:
- Wireless AX Router Nighthawk (WiFi 6) (32)
- Nighthawk Pro Gaming (5)
- Wireless AX Router Nighthawk (WiFi 6E) (3)
This shows which NG routers support WPA3. The R7000 is not included as it was made years before WPA3 was developed thus the R7000 does not have or will not have HW that is required to support WPA3.
IF you want WPA3, you'll need a new router that supports WPA3.
