rardin
Aug 12, 2021Aspirant
V1.0.11.126_10.2.112 firmware blocking NTP?
I noticed a new issue last week after updating my R7000 to firmware version V1.0.11.126_10.2.112. Eventually the R7000 seems to block devices on my LAN from accessing NTP servers on the internet. I...
- Sep 30, 2021
It took several more days of testing that included what appears to have been a cable modem-related hiccup to convince myself that R7000 firmware version V1.0.11.128_10.2.112 doesn't block NTP synchronization a day or two after installation/router reboot. Netgear appears to have resolved the issue that was introduced in firmware version V1-0-11-126-10-2-112.
rardin
Sep 01, 2021Aspirant
rardin wrote:
robjak wrote:Do members of the Netgear tech support staff follow community threads?
Somewhat, but they have been of little help.
There have been DNS issues in the latest FW releases of some routers . This may cause issues with NTP server resolution. Can you change to IP based servers to see if the issue goes away.
I believe I tried referencing at least one NTP server by IP rather than host name as I was trying to resolve the problem, but I can circle back and confirm. For what it's worth, I havn't noticed any other DNS-related issues, but will make a mental note to keep an eye out for them.
I re-upgraded to the V1.0.11.126_10.2.112 firmware, waited a day, noted that NTP had stopped synchronizing, as was the case previously, tried plugging in the IP addresses rather than the host names of a couple of the NTP servers that I use reguarly, but no go. NTP wouldn't synchronize with the servers. I re-downgraded to version V1.0.11.122_10.2.100_hotfix and NTP was able to synchronize immediately after the R7000 booted. I'll be stuck at V1.0.11.122_10.2.100_hotfix until Netgear comes up with a fix. I'm guessing I shouldn't hold my breath while waiting.
rardin
Sep 22, 2021Aspirant
I noticed this morning that firmware version V1.0.11.128_10.2.112 was released last week for the R7000. I pushed the update out to my R7000 a few minutes ago. NTP was able to synchronize with no issues once the router rebooted, but that was also the case after I upgraded my router to firmware version R7000-V1.0.11.126_10.2.112. I will try to remember to check NTP again tomorrow to see if it is still able to synchronize with a time server. Fingers crossed.
- rardinSep 23, 2021Aspirant
After 24 hours, a Mac on my LAN is still able to synchronize time via NTP. At least tentatively, R7000 firmware version V1.0.11.128_10.2.112 seems to have resolved this issue. Will check for synchronization again tomorrow morning before delcaring the problem resolved.
- rardinSep 30, 2021Aspirant
- FURRYe38Sep 30, 2021Guru - Experienced User
Enjoy. - rardinSep 30, 2021Aspirant
Honestly, I'm not sure I've ever had to reset one of the numerous Netgear routers I've used over many years, but that's good advice. I always keep a relatively recent configuration backup on hand just in case.
