rardin
Aug 12, 2021Aspirant
V1.0.11.126_10.2.112 firmware blocking NTP?
 I noticed a new issue last week after updating my R7000 to firmware version V1.0.11.126_10.2.112.  Eventually the R7000 seems to block devices on my LAN from accessing NTP servers on the internet.  I...
- Sep 30, 2021
It took several more days of testing that included what appears to have been a cable modem-related hiccup to convince myself that R7000 firmware version V1.0.11.128_10.2.112 doesn't block NTP synchronization a day or two after installation/router reboot. Netgear appears to have resolved the issue that was introduced in firmware version V1-0-11-126-10-2-112.
rardin
Sep 23, 2021Aspirant
After 24 hours, a Mac on my LAN is still able to synchronize time via NTP. At least tentatively, R7000 firmware version V1.0.11.128_10.2.112 seems to have resolved this issue. Will check for synchronization again tomorrow morning before delcaring the problem resolved.
rardin
Sep 30, 2021Aspirant
- FURRYe38Sep 30, 2021Guru - Experienced User
Enjoy. - rardinSep 30, 2021Aspirant
Honestly, I'm not sure I've ever had to reset one of the numerous Netgear routers I've used over many years, but that's good advice. I always keep a relatively recent configuration backup on hand just in case.
