raznoe
Jan 28, 2020Initiate
V1.0.9.88_10.2.88 r7000 Router goes catatonic
My router provides service to my mothers apartment and mine. She depends on the VoIP phone working. For over a year now I have had nothing but problems with firmware versions after upgrades. I held of...
- Jan 28, 2020
My question is, if I revert, will I be back to unplugging the router once a month? Or will this problem finally go away?---unknown. If its a firmware issue, potentially. But if the issue is firmware plus some other issue such as hardware defect, power supply issue, modem issue, then no. It might continue.
I’m about done with this and will look into buying a different brand router. You people have no idea how frustrating this is.-------we actually do. We've ran into the same issues as we'll as we're the one's recommending which firmware versions are decent. I'd love to say that switching companies will fix the issue. but it won't necessarily. I've had great routers from netgear, great ones from other companies. I've also had a crap one from netgear and a crap 2 from other companies. The more advanced that routers get, the more complex the firmware running them. Which leads to bugs and instabilities. Its not unique to netgear.regardless of what happens, the firmware that most agree upon as being the most stable and reliable is the .42 version. If you downgrade to it, do it over a hardwired connection, factory reset the router afterwards, and don't install from a backup configuration. That's whats been giving people the most stability.
Jan 28, 2020Guru - Experienced User
- raznoeJan 28, 2020Initiate
Thanks for replying. I'm hoping Netgear will pay attention because it is pretty ridiculous. I just reverted to .42, and so far so good. Let's see... What really gets me though is that they went as far as introducing an ad for a new "security" service into the firmware rather than work toward making their existing firmware bug-free.
Yes, you are right, I came to Netgear because of crap from another company. But I have a friend who has a Linksys open source router and has no issues with lockups or having to restart periodically. He's had it running smooth for almost a year now. I may go that route (no pun intended).
Our lives are getting far too complicated and dependent on internet connectivity for this kind of trouble.
Thanks!
