Rachel0228
Sep 20, 2023Follower
Verification email
So I had to change my email as I no longer have access to the old one. I changed the email using netgear.com and it allows me to login but says I need to verify through the verification email. I never...
Sep 20, 2023Guru - Experienced User
Thats beyond forum help. You'll need to contact NG support for that:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
