RHMoore
Aug 16, 2023Aspirant
Very basic question about the Nighthawk X6S, Model R7900P, Tri-Band WiFi Router
My senior residential community contracts with Spectrum for internet, tv and phone service. Spectrum provides modems, routers and cable to all who want them. Every few years, they swap out their mode...
RHMoore
Aug 17, 2023Aspirant
Thanks to all for responding to my R7900P "throughput" question (you taught me to say that đ Some suggestions will take me a while to follow through on.
Simplest one first: the specific brand name and model number of my modem.
Name: Charter Communications (Spectrum). No other hint about the actual manufacturer.
Model number: ET2251.
On WiFi from remote laptop... Task Manager... Performance:
Connection Type: 802.11n
All of the flashing Send & Receive numbers were in the low to mid Kbps range; no Mb.
Kitsap
Aug 17, 2023Master
RHMoore wrote:Thanks to all for responding to my R7900P "throughput" question (you taught me to say that đ Some suggestions will take me a while to follow through on.
Good, the modem model number shows your device is a modem and not a combination modem/router. The combination devices complicate troubleshooting when used with a downstream router like your R7900P.
The Wi-Fi connection type 802.11n is the old 2.4 GHz standard and is limited generally to 100 Mbps data send/receive.
This means your laptop hardware is seriously out of date.
If your computers do the task you ask of them, you are fine. Both your internet service and router are capable of the ten fold increase in throughput you mentioned in your original post.
- RHMooreAug 17, 2023Aspirant
I think that nails it. My old Win 7 made Win 10 machines appear to be the culprits. If that's the case, I can probably bypass the other diagnostic steps you suggested, unless there's more to know in this connection. Either way, you've been a great help.
Thanks very much!
- KitsapAug 17, 2023Master
You are good.
Please mark this thread as solved so others may benefit.
