wgblondel
Jan 17, 2017Aspirant
Very poor WiFi performance since 1.0.7.6 update
Hi, Since I updated to 1.0.7.6 FW, the signal quality is very bad. 2.4Ghz, RSSI : -68 5Ghz, RSSI: -50 I'm at about 7 meters from the router. The weird thing is that the signal qualit...
- Jan 22, 2017
Hi wgblondel,
Try changing the channels of your wireless network.
netwrks
Jan 17, 2017Master
As suggested in the Netgear Release Notes, did you reset the router to factory default after the firmware upgrade?
